Hello, I am new to this forum. Just bought a 1988 Starliner with a 2005 Merc. 250 XS (2005 250 XS XL, serial # OT998344). I am trying to find out a few things.
As you can see from the photo the skeg is pretty heavily damaged. My question is will this effect the performance of the boat at high speeds (chine walk, etc.)? If so, anyone have good shop to send it to to get welded up and painted properly?
I would like to confirm I have a Torque Master lower unit. I have attached a photo of the lower unit head on showing the low water pick ups (four at the nose of the lower unit). I hope this is enough for someone to be able to tell me what lower unit it is. Also, what gear ratio would be in it?
The boat came with a Merc. Fury 25P prop. Is this a good prop for this boat? I was expecting it to have a higher pitch on it. What should I expect to get as my top RPMs with this prop? The engine name plate says it can go up to 6300RPM. The best I got was 5800 to 5900 with the throttle all the way open (no more movement left in the gear shift lever at the helm - I have not raised the engine). I am trying to figure out if this is all OK or do I need to get the engine looked at.
I also would like some input on what would be the best setback for this boat and some prop ideas. What should I expect as the maximum top speed considering the hull and engine.
I'll take any ideas and advice.
Thank you very much.
Trip
P.S. I'll get the photos up ASAP, once I figure out how to.
Trip
