I have just replace my tired 330 with a biult 330 from jasper.the problem i'm having is the new motor will not run over 4400 rpm. it was showing lean the first time out so i decided to get rid of the q-jet ahd installed a 850 holley a friend had. i know the holley is a little big i just figured on rejetting it.after the carb change it still showed a little lean with original jets in carb. so i cleaned and checket the fuel system. replaced fuel pump and filter.ran it again still wot 4400 and the plugs are showing color with a little carbon. timing is advancing to 32 degrees at 3800 rpm's. in nutural motor will spin to 5000. have a 25 3 blade with a 1.65 out drive. new motor is 370 hp ??? ANY IDEAS ??
