Bravo 1 outdrive oil handpump?
Diplomat82
My previous Checkmate had a pre-alpha on it with the drain plugs for the outdrive on the side of the case. Now on the Bravo 1 the drain plug is behind the prop and neither of my hand pumps will fit in there to screw in. I take it there must be a special pump for them.
What ones do you Bravo 1 guys like?
Just get a new pump with a longer plug adapter. Its about 1 inch long, plastic and has tabs to screw it in, $10 bucks.
Just was curious if people had a type or brand they really liked.
I had a real nice one with a metal fitting but it is too thick to get in there. I do have a crappy cheap plastic one but it has tabs on it that I could possibly cut off.
