Convincor 253 Windshield trim(1997)
253SED
has anyone found a place to buy the black foam type material that goes on/around the bottom edge of the windshield...it has been dry rotting and coming apart thru the years and needs replaced.....thought I read a post on here before about it but cant seem to find it.....thanks
Best bet would probably be to call the factory. If you find something, post it up cause I'm sure I'll need it at some point too!!
Window Seal
I used the foam from a prosthetic manufacturer that they use to cushion the skin from the device. It cut and molded really easily but holds the glass like Iron. I then sealed it with silicone for a temporary solution. Works great but if someone can find out where to get the original seal I would be interested.
