Guys,
Was out the other day and the Engine Monitor Alarm went off on my 2004 Johnson 115 V4 Looper (J115PLSRC). The system check goes on when you first turn the key to the "on position" and the gauge lights up in sequence starting from the bottom and works its way up on the indicators. This is normal according to the manual.
Then as the motor is running I get a beep every couple of minutes and the gauge lights up again in sequence again from the bottom up with none of the indicating lights staying on? It seems to happen at idle speeds only, under 1500 rpm. It seems as it is doing the system check again and again?
The 2 stroke oil tank is half full, the motoring is peeing out the back and the motor will rev past 5500 rpm. At one point the trim stopped working as well as the tach then started working again with no problems?
Thoughts?
Thanks guys for any help!
Thoughts?
