FOR SALE: 2002 Checkmate ZT280 in IN
bebbmi
[FONT=Helvetica, Arial, sans-serif]Just wanted to touch base with you to let you know that I have a very clean 2002 Checkmate ZT280 power boat for sale. It is located in Evansville, IN (southern tip of the state) and is available for immediate delivery. I will be interested in replacing this boat with a 32/33 ft. Checkmate or other brand boat (Donzi, Cigarette, Scarab, Sunsation, Fountain, etc.) within the next 6-8 months.
Brian Buxton
Evansville, IN 47715
(812) 760-5513 or bebbmi@sigecom.net
[/FONT][FONT=Helvetica, Arial, sans-serif]2002 Checkmate 280ZT stepped V-hull powerboat (VIN: CHK46358G102), white gel coat hull with custom 5-color clear coated graphics by Mitcher T. (purple, red, black, yellow and orange - $6,000.00 custom paint), white interior with purple accents and snap-in purple marine carpeting with black edging, 215 original hours, inboard Mercruiser fuel injected 496 H.O. engine (serial #0M084815) with heavy duty offshore motor mounts, 425 hp., 5,300 max rpm., operating range of 5,000 - 5,100 rpm., Bravo One stern drive (serial #0M116582) with SS transom shower, two (2) Mercury Racing Bravo 1 balanced and blueprinted 26 pitch SS 4-blade props ($1,000.00 each), 45 mph. cruising speed, 70 mph. maximum speed on GPS, 6 person capacity, 75 gallon fuel capacity, dry weight of approx. 4,900 lbs., 28'1" total length with swim platform, 8'5" (103") beam, 24° deadrise, 24” draft, 5’ bridge clearance, 2002 purple C-Hawk tandem axle trailer (VIN: 1L9BZ282721102015) with Dico surge trailer braking and polished 6-lug American Racing Outlaw II rims (horizontal trailer mounted spare) included, GoodYear Marathon Radial D load tires (ST225/75-R15) with Tread Depth Measurements: PF: 9/32, SF: 9/32, PR: 9/32, SR: 9/32, spare: 10/32 (10/32 is new tire tread depth), hand laid balsacore construction, stepped hull and flat-top deck, foamed in-floor, full fiberglass innerliner and bulkheads, fully integrated extended swim platform with three-step telescoping stainless steel ladder with anti-slip surface, heavy duty custom aluminum gas tank with SS gas filler, custom wiring harness, dash mounted emergency engine shut off switch (mounted to wrist lanyard), electric bilge pump, electric bilge blowers, electric engine hatch, anodized engine compartment vents, Corsa Captain's Call Quick & Quiet Plus thru-transom electric select exhaust, Insta-Trim Heavy duty racing electric trim tabs w/ trim tab indicator, Imco external hydraulic steering, Kiekhaeffer zero-effort drive lever and throttle with trim in handle, quick change oil drain tube exiting through a rubber hose at the brass hull drain plug, full snap-on cockpit cover for trailering and short term storage, tie-down full boat cover for long term (winter) storage, Sunbrella retractable / removable cockpit umbrella, SS popup bow light, removable stern light, vinyl gunwale trim, teleflex tilt steering wheel, 3-spoke white soft touch wheel, upholstered thick bolster seats, rear bench and sun pad, standard cabin interior with 2-couch lounge seating, fill-in cushions for extra sleeping areas and 2 swiveling halogen cabin lights, large sleeping berth with privacy curtain and fluorescent lighting, locking sliding cabin door, locking 17" tilt-up deck hatch with removable screen, Thetford Marine Port-a-Pot removable head, cockpit and lounge area drains, six (6) drink holders in cockpit and lounge area, snap-in purple marine carpeting with black edging, mechanical drop-down bolster seats, lots of standard stainless steel (windshield frame, 5 pop-up cleats, bow rails, shocks on hatch cover, interior grab handles, pop-up bow light), Alpine CDA-9820XM AM/FM marine radio with XM radio, CD player with remote control and dual cone marine speakers, Livorsi reduced glare full instrumentation (with purple anodized gauge bezels) including: speedometer, tachometer, oil pressure gauge, voltmeter, engine temperature gauge, fuel level, drive trim, trim tab indicator and digital depth sounder, Lowrance GlobalMap 3600C iGPS color marine Chartplotter GPS/NAV system with internal antennae, Lowrance NauticPath USA electronic marine charts card, large storage areas in the engine compartment as well as in the sleeping berth, behind each couch in the lounge area and under the rear bench seat, 12V receptacle, curved, tinted safety glass windshield with SS surround, engine compartment mounted engine hour meter, Halon fire extinguisher, marine horn, purple powder coated anchor, new marine battery with heavy duty battery tie-down, always stored in a heated and air-conditioned building (summer and winter), fresh water use except for 1 week in FL and otherwise never left in water overnight, 3 owners since new, cleaned after every use and hand waxed twice a month!, replacement value of $100,000.00, extremely clean boat inside and out, all books and manuals, lots of service history and just serviced for the year, a rare hand made powerboat with custom Mitcher T graphics, I am extremely particular and can pretty much guarantee you won't find a cleaner pre-owned powerboat, offered at $59,950.00 / best offer. Call or e-mail for more photos!
[/FONT]
