ignition problem
tonywil33
i have a 25 ft convinsor with a 454..under a heavy load it seems to have a miss only after you run it for like 10 minutes.can you pull the factory ignition and distributor and put in a hei set up...
Sounds like a ignition coil to me.....check that out.....those usually start giving problems once things warm up.
Sounds like a coil also to me. I prefere a msd set up if I was going to change it.
I run a performance aftermarket HEI in my 251, works great and inexpensive....I do not like MSD stuff failure rate way to high now as they outsoure much of their componants from china...
What the H E L L isn't made in china anymore
