nickhedstrom
96 225 Pro Max, I had the boat out several times this year prop testing and it was running fine, 6200 RPM at 74 mph, I had a mechanic stop by and i showed him my left side voltage regulator and he said it was bad which is why I had low volts at low rpm, so i changed it out and my volt were up. So last saturday i had the boat out and it was running perfect all day, the next day i took it out i could barely get 4500 rpm. So i changed plugs to diffent type BR8HS, and it still ran rough at idle in driveway, cleaned all plugs to look like new and reinstalled and ran at idle for 5 min and removed and 4,6, and 1 plugs looked very clean and 2,3 and 5 were black like they been firing and the others not. I did find a weak coil on 3 and replaced it but still a problem. Took it today to a Mercury dealer and they did a spark test and it came out good. They did a leak down and found 1,3 were at 10%. Pulled the head and the gasket was not blown but very little scoring. Dont think thats the problem for the way its running. When i was running it in the driveway for little time the prop turned very black. Anybody got any ideas of which way to go next or have had simaler experence like this? Thanks
