Mark A
I had tried a 19” Mirageplus for a demo and it was much better than the cheap prop but it too would porpoise with any trim so I did not keep it.
From all that I have read, a “stern lifting” prop should help and a 4 blade prop might be another option. Also mentioned is moving weight forward away from the stern. I moved the batteries forward as far as I could mounting them in under the rear bench seat. It seemed to help a little.
Any suggestions for a prop or other suggestions would be appreciated.
I wondered though the following:
1. If anyone had ever moved the fuel tank forward in trying to improve the dynamic balance of the boat. I replaced this tank when I purchased the boat and there is about 10 inches in front of the fuel tank which I believe would shift a good chunk of weight forward.
2. Would the factory or builder of a boat like this shift the tank forward when they built this boat and equipped it with a big block (heavier) engine?
3. The Mercruiser 6.2 Horizon closed loop cooled engine requires water be fed from the bravo drive and be fed from a secondary through hull fitting (through hull intake strainer) like shown here:
http://www.freshwatersystems.com/p-2823-bronze-one-piece-intake-strainer-34.aspx
Could the strainer be a factor being in the area of the bottom of the boat a couple of feet or so from the prop? If so, how else could water be fed to cool this engine? How do they do it on new boats? I found that there are stern mounted water pickups and wonder if that would be a better than the through hull strainer.
