I'm concidering a new prop for my boat, since it's about the only thing original on it, and I don't think it's working like it should be.
First off, I don't know what's on there now. I can't see any numbers stamped on it. And it's a 'cleaver' style prop, the 3 Stainless blades are sharp and pointed, not rounded. I don't know what the point in that style prop is either.
The boat is a 1984 Convicor, 25 feet. A newer Merc 7.4 L9 454, MPI. I also have a TRS outdrive with a B&W transmission.
Currently, I am turning 4600 WOT, and only getting about 50-53MPH (GPS, depending on load inside boat, like fuel, people)
What's a good recommended prop for this boat. I care more about mid-range speed & effieciency and being able to plane then hi-speed running. I normally cruise about 30-40MPH with a few people onboard. I make long runs to the islands, about 45 minutes away. I also like to get on plane fairly quickly since I do wake-board and ski behind this monster.
Any advice on a good prop for this setup??? And what's my current prop style used for?
Thank you
Thank you
