Thanks ...it has a Mazco 3 not sure size tho..I'm in williamstown..it's about 60 miles to from me..I'll let you u what happens..guys a ill high on price in this market
wow thats alot of eyes!Been running that combo for 17 years. Is it a true 2.5 carbed 245 h.p. What cle lower unit does it have 2 or 5 hole. be aware of the 2 holes unit. The larger 2 holes allow for seaweed to enter and block the water flow. it don't take much about the size of a thumbnail, turning at 7000-7500 rpm they blow quick. If it has a 2 hole always have a way to open the inspection plate and a coat hanger bent like a button hook to fish out the proplem from the bottom up.
As for props I've never spun anything else then the lazor II 21p that came on it. All out top end never worried me. The starflite is a heavy hull for that mota, suited more the hi flyers and ultra lights. Low torgue-high rpms so don't overload with to much prop enless running nearer the surface.
With the 21p new and dry hull it spun out to 7500rpms right at 75mph with the 5.5 cmc hyd jack. Now with 15.5 setback with a wet,tired hull still over 70 mph.
Learn to drive 1 eye on water, 1 eye the presssure gage, 1 eye tempture gage, 1 eye on your fuel gage, a look out for water out streams and ear to the rear you really shouldn't have a proplem. Oh and change your rings every 200-400 hrs too! The good ones are $500 a set.
Cheers: merc245 (get it)![]()
wow thats alot of eyes!![]()
i figured that..now its 2500..said there a rod nock..lol..know any good merc repair guys
