cbattles
I just rebuilt a LOT of my Trimate II.
New transom, floor, etc. I copied a lot of what I saw on here with the transom - ended up doing 3 sheets of 3/4" ply, put in some knees, etc. So, there's definitely some extra weight in the back compared to what would have been there originally.
Also, as of yet I haven't put anything back in the front besides the floor, so there's no seat, extra wood panels, or passengers to weigh the front end down.
I have a jackplate with 6" setback, the prop shaft as of now is about 2.5" below the centerline. I'm running a 24" Trophy+ on my Merc 2.5 175.
In terms of just raw performance, it's great. Trim all of the way in, if I get into the throttle, it'll stand the nose right up, jump out of the water onto plane, and just run.
Problems:
1. If the lake is anything but completely smooth, it's downright scary. At 40-45 mph plus, it's always about one decent ripple from hopping off of the water.
2. It doesn't like to plane off (or stay on plane) at lower speeds - I think this is because of how stern-heavy it is - it wants to either run fast or not at all. As soon as it's not going at least 30 mph, the stern just starts to set down in the water and the nose just starts to stand up (quite a bit) until you're back in the throttle.
If you put a tube/skier behind the boat and try to run at a reasonable speed (not overly fast), it doesn't take much to make it start (what I assume is) porpoising. In fact, it's difficult, but at certain throttle positions/speeds I can reproduce this without pulling anything.
Overall, it's just uncomfortable to run in and I'm really kind of scared to let anyone else drive it.
I've thought about some transom wedges, I think negative trim might help keep the stern up some and the nose down. I've also thought about just tossing some extra heavy stuff (like a couple sand bags) in the front or overbuilding whatever seating I put up there. I would really rather not resort to just weighing the boat down though. Any suggestions?
Problems:
