My 1973 Evinrude 115HP engine has not been run in several years. I am now ready to get to business with it. I filled the lower unit with grease.
I unfroze the cylinders and got the engine turning freely with a 34mm wrench. Then without hooking up water I just briefly connected the engine to a battery to see if it would turn over, it did. Hoorah!
Next (come spring) I intend to install a new water pump kit. Hook up the water earmuffs and see if I can get the engine to actually run for a few seconds. If that works, then I will back the trailer (with the boat on it) into the lake and try to get the engine to perform properly. Have I screwed up yet??
Do my plans for the spring make any sense to you??
Thanks,
Clarencio
Thanks,
Clarencio
