The boat interior was gutted to bare hull and then rebuilt. Then I ordered and installed a new interior from Checkmate. New carpet, new wiring (except for the horn), new gauges, new bilge pump, new battery, new control cables, new steering wheel, new stern light. The hull is in very good condition. There are typical scratches below the water line, no holes. I have lightly sanded and polished the metalflake above the rubrail. Needs polishing below the rubrail, but you wouldn't know it from 20 feet.
The motor runs but needs work or replaced. Even with work, I wouldn't trust the motor for more than a season or two. It starts and runs great on the hose, but under load it dies. I have rebuilt the carbs and the tilt/trim cylinders and replaced some wiring (mostly grounds). Installed a new impeller housing and impeller. I think I have all the gaskets for the motor, a new alt. belt, and other misc. parts/pieces. I was planning on digging in to the motor, but lost steam and then we decided to adopt...nuff said. The prop is SS and like new, 19P I think. The motor is mounted on a new 6" adjustable jack plate. Everything works.
The trailer is all brand new except of course for the frame. The wheels are used Ford Ranger alums. New axle/hubs, new tires, new spring bushings&suspenion hardware, new poly rollers, new bunks, new lights/wiring, new jack, new winch, new diamond plate, new hitch, new rustproof coating and paint. As far as I can tell, the trailer is from an old Ranger Bass boat, so the trailer is beefier than this boat requires. It pulls great and can go anywhere you want to pull it with no worries at all.
$2500.
mike@ridlon.org
$2500.
mike@ridlon.org
