Rcenter1
http://indianapolis.craigslist.org/boa/5233887713.html
Check out the CL add for pictures and videos. Thanks
Boat-509hrs
Engine-59hrs on rebuild
Titles for boat & Tailer in hand.
As Is it does 72MPH with a 3 blade 25 Pitch. I can get mid-upper 70s out of the labbed 27 pitch Hydro 4 blade but its not mine to let go with the boat. The boat may push a 30P, i may try at Ceaser Creek shootout if not sold by then.
This Boat has around 620HP @ 6100 - 509 Spec By Bob Madera Built By Slingblade Performance in Anna, IL. Bravo 1 Drive, MSD true Marine Ignition box, coil, & distributor. Gill marine (Dry To The Tip) exhaust and boat leveler brand trim tabs. Boat could obviously use interior work but its as good as it gets mechanically. I may be interested in interesting trades. Jeep, nice car, Zodiac with nice outboard etc... I have videos just email me. I will try and get cash 1st though.
firing order 18726543
1.7 rocker
hyd roller
lobe seperation 113
valve overlap 17.6
center line 110
int duration 240.1
lift .65457
exhaust
center line 116
duration 247
lift .6377
Springs at Isky Endurance .
new PBR high Endurance lifters. Z bar type.
Push rods; intake, trick flow chromoly,exhaust are comp cams chromoly.
Main Bearings
http://www.atechmotorsports.com/parts/CLE-MS829H10
Rod Bearings
http://www.atechmotorsports.com/parts/CLE-CB743HN10
Pistons
http://www.summitracing.com/parts/SRP-139482/
Boat-509hrs
1.7 rocker
hyd roller
lobe seperation 113
valve overlap 17.6
center line 110
int duration 240.1
lift .65457
exhaust
center line 116
duration 247
lift .6377
Main Bearings
Rod Bearings
Pistons
