200 BlackMax Questions
did you check the primer bulb while the engine was boggint - was it flat - just want to make sure the fuel pump is doing it's job. the bulb should be hard at all times while the engine is running
Hmm I haven't looked at the bulb while it is running.... I will try draining the main jet. And I am running premix!!
While its bogging have somebody pump the bulb to see if it picks back up. I would be real concerned about the buzzer going off
Well, ITS FIXED!!!!!!!
I finally took it into 2 Guys Marine here in Del Rio, and for a *nominal* fee they fixed it up :) Turns out, it wasn't the carbs, the stator was going to hell in a hand basket and they also discovered that one of the spark boxes or something like that was out. SO, it being an electrical problem, it was not cheap to have fixed, but it runs like a bat outta hell! It ran so good, that I spun the prop on the hub! Doh! However, a quick trip to 2 Guys, and they had the locked prop nut off, and a new composite hub installed in no time! Thanks for all who helped!
