I am in to the second week of a restoration project on my 1974, 16.5 ft open bow Trimate, Checkmate. It has been the familes ski and fishig boat since it came off the show room floor in Bossier City LA. the floor had rotted out and badly needed repair.
I have spent 2 weeks removing the interior and the flooring, and found the stringer totally rotted out. and most of the wood center core rotted...
I have been reading lots of restoration forums and have a good baisc plan in mind to rebuild it back to gold standard... lookig to go with Expoy, on 1/2 exterior plywood... with one elayer of CSM on the bottom and a couple layers of CSM on top with a final layer of woven roving. And using 1708 to tab it in.... not sure on using PL or peanut butter for my padding and filler??
All my reading I am confused on the construction of the Trimate.... It has a single stinger down the middle supporting the floor in the back 10 ft. and the area under the plywood is filled with foam.... Did Checkmate intend for the Stringer and foam area to be water proof with no drainage to the Bliege and drain plug????????? It appears to totally fiberglassed in. and allow the water to drain across the floor to the bliege area.... However some of the artilce I have read talk about adding small daringe holes to allow any water that gets in to drain.
I woudl like to build the floor water proof and not build it to drain just incase I knock a hoel in the hull...
Any smart boat people with Checkmate thoughts????
Richey
Richey
