tastethefreshness
first off i cleaned the fuel screen cause the boat seemed like it was starving for fuel when you would go fast about 45 or higher slow back down to 30 it would run fine. after that now when i first start it(sometimes), it seems like the system wont hold pressure so i have to pump the ball while its running every min or so. but then after it has been running for a few mins (mosttimes) it seems to hold pressure. get up to about 45 and it will run good for a min and then starve, i slow back down to 30 will starve for a min then work it out of the system and run great. i also had it the other day i went to take off the gas cap and i had to use pliers to get them off so much suction in the tank, but it doesnt always do this. bad breather on the take, fuel pump, diaphragm any ideas?
