STARLINER IS HOME!!!!
OK, guys - not to divert the topic away from silly town names, but I GOT THE BOAT OUT!
First thanks to Ross, Kurt, Mr. Buss for the offers for help. You don't run into that sort of thing too often these days.
Second, I finally have a BUNCH of pictures posted on photobucket:
http://s293.photobucket.com/albums/mm61/picbucket2008/Starliner Barn Crash 2009/
We got up there on friday night and moved a fair bit of snow with just the truck headlights on - enough so that we could get salt packed around the pontoon tires and my frame. The whole barn basically became a skating rink with about 8" of ice in it. The Pontoon tires were stuck in that ice. Check the pictures. We used a breaker bar to split it up and a manure shovel to move it.
We had the pontoon out by about 9am on sat. morning - all it took was some digging, that salt, a heavy foot on the gas and about 4 ft of slack in the tow strap! We were considerably more careful about 4 hrs later when we pulled mine out.
I carefully got the snow off the boat, which wasn't that bad. There was a lot of ice that must have come from the roof and half-way melted on to the boat. Luckily the cover made that pretty easy to ice off.
I am amazed that the boat and trailer didn't break from all of that weight - there had to have been over a ton of snow and ice ON the boat (plus what was IN it). One tire did go flat but that was it. So after we got as much weight out as possible, we filled the tire, jacked the tongue and put a new tongue jack on. Then we wheeled it around and around to get it through the opening. We ended up having to move alot more ice to get it out.
Now to the problem - when the roof fell, tongue jack broke so the boat was tipped forward. The boat was (and still) filled up with ice. Even though the plug was out, the entire thing was filled up with ice. Maybe it froze slow enough and had enough room to expand upward somehow, but it doesn't look like any damage happened when the ice froze and expanded. I guess I won't know for sure until I can look at the ski hole and stringers in the back that I can see.
As the boat sits in my driveway tonight (uncovered!!), the hole and front of the boat filled with solid ice - I could open the starboard side front bench seat and it is still about half way filled with ice. The port side is still iced shut - there is a pic of the ice there. The wakeboard and throwable cushion are still iced in.
If there is no ice damage, then it's just the crushed windshield, a few interior cushions and a few pretty minor gel coat touch up areas. Radio and fishfinder too, but that's easy. I'd also like to try to get a new carpet out of the deal. I've talked with Kary and also Kevin Brown of North Shore. I'll probably end up taking it to Kary if he's interested in this type of work.
I'll keep everyone posted on what happens. For now, please keep an eye out for a port side front windshield. I suppose it can be fabricated somehow.
