Enchanter Prop Question ?
85vmax
'87 Enchanter...21' with a '87 Merc 200...low water p/u on a 6 " plate...prop sitting 3-4 inches below the pad.
Took her out on some flat everglades water...........all I could get was 47mph gps @ 5000rpm at WOT.
Finally took the prop off its a Turbo SS 14 1/4 x 25...which seems the norm for my set-up by all the info on here....motor runs good.
Is the pitch too high...I'm seeing some running 23/24's on here but running 10" plus plates.
Any feedback welcome.
I'm running a 25 pitch prop on a 95 Mariner 175 (2.5L) on my Enchanter and have seen speeds as high as 61, RPM's in the high 5000's. I don't have any exact details on the prop, I bought it on eBay a few years ago and the only marks on it are the number 25 etched on the side with a dremel. Pretty sure that's right as I also have a 21 and 23 pitch prop and both let the motor rev higher but have slower top speeds. I'm thinking about trying a 26 or 27 pitch prop. I have a jackplate with gives 6" of setback and I normally run it as high as the jackplate goes (but my motor has a 25" shaft.) I just measured it and I'm about 5-6" below the pad at max jackplate height.
I have 1979 Entertainer which is the same hull running a 2003 Merc 200 carb model with 5-1/2" of set back and turn a 25 Tempest or a 26 chopper. Prop shaft is 5" below the pad. RPM's 5600 - Speed high 60's.
I run 1.75 below the pad but have a 14" jack and a very beastly 2.4.
24 labbed chopper stretched to 25 6000 rpm i'm right at 70.
At one inch below alone in the boat different prop 76.
Rat rod, minimum interior light boat..... your mileage may vary.
Love the enchanter.
Adding 1/2 inch to the last 6 feet of my pad and blueprinting this winter! going for 80!!!!!!!!!!!!!!!!
