Pretty sure the trim on those old OMC's use the front mount to move the drive. So when drive is trimmed up the front of the motor will be low and when the drive is trimmed down the front of the motor will be high. And then it also has the tilt function what is a gear drive on the side of the drive. I may be off on that tho as i am not sure what years and all they used that system.
Also make sure you check the drive seal real close! I have helped pull a boat or 2 off of the bottom due to that seal drying out and cracking causing a quite large water leak!
Looks like a good deal. Just wondering what the last 2 digits are on the hull id.
Looks like your missing the pads on the rear deck and I don't think 79 had that deck.[/QUOTE
i actually found original ad on ebay that looked just like it.the rear deck a little weak.i dont want to put a flat deck on it.im gonna eventually put 350 with single carb tunnel ram with scoop later on,but not sure now if motor really moves with outdrive.i want the look mostly original.so whats the hull id?its not the vin is it?maybe i got a late in the year body of a 80 model.
and please tell me more about what your saying,because the other day it didnt look low in front.i just dont think it will lookright after putting high rise and stuff
How large is the hole in the transom compared to a Alpha. If the Alpha is bigger maybe find a junk boat and transfer a alpha transom Assembly and drive that may be the way to go. you can usually find rotten boats on craigslist for cheap to free to get all the parts you'd need for a conversion.
hull id is on the port rear corner of yours.
79 flat deck http://checkmate-boats.com/photopost/showphoto.php/photo/117/title/1979-8/cat/514
80's padded deck http://checkmate-boats.com/photopost/showphoto.php/photo/145/title/1980-16/cat/515
Not saying your wrong I'm always just wondering.
Like Keith said your Hull ID is on the rear corner of the boat and will look like CHKXXXXXXXX. Another thing to consider would be to get the correct OMC Inboard Engine Service Manual and OMC Sterndrive Service Manual for the for your year of boat. They are available at Marine Engine.com or you might be able to find them on Ebay, but would be quit valuable to you as you work on you boat. Jim
