I'm installing an indash depth finder in my 1980 Entertainer this weekend. I would give anything to avoid drilling a hole through the transom, and the unit I selected does have the capability to give through-hull readings. However, it specifically states cored hulls will reduce effectiveness, and recommends using the in-hull setup for solid fiberglass or aluminum hulls. If I place the transducer in the engine compartment directly below the engine, will the unit work at all on an older Checkmate? Or is there too much wood in the hull for it to get through? Am I going to have to drill holes to make this thing work?
