predictor paint restore
jtellor
Well i picked up another checkmate last friday. Its a 79 predictor. I already own a 82 enchanter and i love these hull styles. Couldnt pass it up....it had an 80hp mariner on it that had bad electrical problems/fire. It looked like all of the wires were cooked on that thing. I had bigger hp plans in mind anyways so i asked him if he would just sell the hull and trailer...$500 later and a 30min trip and its in my driveway. It is all original with a decent interior. I was told by the PO that the gel coat was un-restorable. I kind of thought otherwise. So After getting frustrated while trying to buff out the cleared top on my enchanter i messed with the predictor a litte. I wet sanded with 1200 followed by 1500 then 2000. Followed that up with presta ulitimate cut compound on one of there heavy cut pads. Here is the pics. It shined up pretty nice but not quite like glass. Im thinking about trying the other side with 800 first...then move up from there. Also going to try to get a polish with some sort of foam pad to finish it off. It will never be perfect as there are alot of little weather cracks in the gel but if anyone has any tips to make it shine more let me know. Here is a couple pics.
I dont actually know.. Some might be scratches but most look like tiny cracks. This thing is really sun baked. I can post up some more pics if you want.
If it's scratches you'll need 600-800 grit to remove them. Then work your way up 1200,1500,2000. If it's cracks you'll need to grind them out. Post up some more pictures.
i dont have any close up but i have a couple more of the work i did...i only buffed half of the top btw. Also if i cracks/scratches are all over...just looks weathered. Just probably was left out to bake in the sun for years and years. Im not really to concerned with those as you can only see them from close up. If i ground them...wouldnt that mean a re-gel or re-paint?
BTW that white spot was from the PO...guess he tried to buff without sanding and then gave up. I guess thats why he told me the gel wasnt saveable
The side you worked on doesnt look to bad caompared to how the other side looks ..... Nice boat
Thank you...This boat was too good to pass up. I only ended up giving $500 for it. it had an 80hp mariner on it but the wiring was shot and all melted. I knew i was going to want more anyways...so he kept it and knocked the price down $300. Ill post some more pics up when i finish getting it cleaned up. I might go ahead and post up a thread in the restoraton section.
