so this 4 blade trophy prop im looking at has vent holes...whats that about?...
Had a little chine walk...guess ill have to push through that John, in response to your post on the plugs in the prop...good info by the way...so far with solid plugs seems ok out of the hole....would it be wise to try a little opening?
...so my thought was to buy a hydro with 10inch set back....unless you know of where I can get rebuild parts for my land and sea hydro plate? then i would buy a manual plate...hmmm.... maybe i need to re think the set up...Ok, I just picked up a used 23 pitch 4 blade trophy. For 150 bucks. Should I get it rebalanced to make sure it's fine?
