I gave up on the compression check after I got hung up on the spark thing.
I don't have a manual, but obviously I am going to need one. I have a multimeter so I am all set there.
The plugs that I did remove looked OK, however they are all fairly new so it's tough to tell. The ones that are marked as not firing or intermittent did have a darker color, so that may be a hint. My guess is that when the engine is spooled up, it gives spark to each cylinder well, hence why it works better at high RPM and bogs at low RPM.
Yes, I had a good ground when testing spark, I tried the block, the plug itself, the plug base. I ended up trying even more on the ones that would not work.
I think I am on the right track. I find it hard to believe that it would pull that strong at higher RPM's if it was a compression issue, but I will still check that once I get this spark issue sorted out.
Anyone got a manual they want to sell? LOL
but....
